Hey thanks for the offer.
I wasn't sure where to ask this.
So she found these rims on BerkshireTagsale, a facebook group. :xyxnervous:
They are Enkei RS5 17x7 and there are 2 sets of 5bolt patterns. The offset i think is 40mm
The tires that came with the rims are Federal 595 i think. at 205/40/17
I'm not sure what the 2 bolt pattern are.
Thank you for the additional information,
Rujo.
The wheel dimensions (17x7 ET+40) are going to fit the vehicle just fine; I'm not sure if she purchased the correct bolt pattern, though...
The 17-inch 5-lug dual drill RS5 was offered in three(3) combinations: 5-100/112, 5-100/114.3, and 5-115/108. The bolt pattern for the 2013 SI is 5-114.3, as you likely know, so as long as she purchased the 5-100/114.3 combination you two are in good shape.
When it comes to the tires, the 205/40R-17 is not going to work. This size is approximately 1.25-inches shorter in rolling diameter when compared to factory, which is going to cause inaccuracies with the odometer and speedometer. This tire size is also grossly under rated for the vehicles load carrying requirements and is not safe for the vehicle. If you need to purchase new tires for the wheels and would like assistance with that, let us know and we'll help you select a safe tire model that fits your needs. We have deferred interest financing for up to 12 months available as well; see the link below:
Details:
EASY CREDIT CarCareONE Card | Discount Tire Direct
One other thing I'd like to mention, and assuming the correct bolt pattern was purchased, we have hub centric rings available for this application if you need them. The hub ring set is only $15.00 and ships FREE! We also have smaller diameter lug kits available for $45.00 if you need that as well.
