Status
Not open for further replies.
1 - 20 of 43 Posts
Gonna make this thread real simple....
COUPE ONLY
SEDAN ONLY
Any bulb/LED you need simple type it is as you see it shown. In many cases, bulbs are T10 or bigger.
Simply type in the bulb you want
Example:
Backup Lights uses 921
Search for "921 LED" or "921 LED Projector"
Get something like THIS
Do the same for any bulb/light/LED you wish to get your hands on!
It's that simple :smile:
ALSO**
7440 and 7443 are both T20 wedge style lights. Both will work similarily
921 etc is T10 Wedge style :)
No problemo :)
Hope it helps us all :)
Hola
Discussion Starter #11
Only because you need the shorted stem light tho? Not different wedge type? Is it not a T20 fitting?
Hola
In your diagram it says 921 bulb, which is for the coupe. But the sedan needs a 7440. I originally bought the 7440, only to find that it doesn't fit. I'm not sure if there are any other differences between coupe and sedan though.
Discussion Starter #13
ok so 921 id T10, 7440/7443 are T20. T20 is slightly larger. I'm sorry. Making one for sedan :)
Discussion Starter #14
**Updated**
Thank you! $4.47 on eBay (LED reverse lights) and $115.15 on idjmtoy (LED front and rear turn signals, front and rear dome lights, license plate light, taillight/brake lights, and trunk light) later, I'm happily waiting for Brown Santa to bring me my Christmas presents early!
Edit: thanks to BLACK18 coupon code ijdmtoy total was only $93.17!
Discussion Starter #19
lol crazy! 93 vs like $5 haha
anyways glad you got what you wanted :)
Damn i couldve really used this a couple of days ago... Ugh, then again i knew i should've checked here before buying. Now i gotta send back some reverse light LEDs that don't fit. GG! Informative post though, thanks!
1 - 20 of 43 Posts
Status
