How underdrive pulley makes power ?
Engine accessories cause parasitic drag, it robs engine output away, it’s why when the ac is on, the car feels more sluggish, the alternator is charging, its creating drags…m
when you upgrade ANY things that rotates (wheels, rotors, flywheel, cams, tires, pulley) to lighter weight, it’s reduces load, on pulley, it helps crank use less energy to spin the whole accessories, it’s the same effect on the other side of the crank, when you install light weight flywheel, it’s free up so much weight and now the crank have much less weight that drags everything down..
So, when you have light weight pulley or flywheel or both, the rpm can move much faster, you can hit peak power at a much faster rate… why do you think I can dyno 198whp @ 7000rpm with no hondata/tune or catless dp ? it’s not magic, it’s all largely because of underdrive pulley kit & ram air…
