1 - 4 of 4 Posts
My EX Coupe just turned 100K. I started noticing a clunk in the front suspension when going over small bumps. I check the sway bar links and found one had failed completely. So I replaced the sway bar links and ball joints. Still have the clunking sound. I'm thinking struts (?) Any thoughts on what to look for will be greatly appreciated.
front struts is a possibility, could also be the upper struts mounts/hats too. They have a bearing inside and when they go bad they can make clunking noises too
Did you replace the control arm or just the ball joint? I think the noise on my 13 Civic LX is coming front the front side bushing, so I've decided to just replace the whole control arm.
1 - 4 of 4 Posts
