These are the rarest type of UAE spec projector headlights that actually come with D4S HIDs. I've had these in use for 9 years and they are still on the original bulbs!
Like the other sets that were bought up from an ebay, they were clearly "factory defects" that someone got a hold of. Mine weren't too bad. One has a redundant broken tab (pictured) and the other has some deep vertical scratches (pictured). Since neither affects operation and the scratches aren't noticeable unless you look for them I called that a win.
I did have someone recently refinish the lenses and apply a new UV coating. They are much better than before (not hard after 9 years of daily driving) though there are still some light scratches a perfectionist might want to go over.
Included with the lights are re-done harnesses (with resistors for the outer turn signals), a new set of Philips D4S bulbs, an extra ballast, an extra bulb connector, an extra projector (not sure how useful it will ever be, but you'll have it!), and extra connectors if you want to change the harness. I didn't like using the inner amber lights, so the harnesses do not connect to them. You'll need to modify the harnesses and grab a new connector and bulb for the driver's side if you wish to use them.
Price is shipped to the continental US. Local cash pickup is $750. Let me know if you have any questions.
Thanks for looking!
