Late to the partay here! The issue, as I'm sure you know, is that there is *very* little room to spare with a 3" exhaust system. Another solution other than just going to different exhaust hanger bushings (which is a good solution) is to use pipe clamps around the stock bushings. Tighten them enough to get things in position while still leaving some room for movement. You may need to put zip ties around the bushing the other direction to hold the clamps on; get creative... Also, I didn't see it stated, but if you haven't, a stiffer rear motor mount is pretty much a necessity for a larger exhaust otherwise the engine is going to move too much. . .
