1 - 10 of 10 Posts
Hey, the fuses under the dash with no purpose, is it safe to use? I mean the ones with no fuse in them and the manual just states them as blank. Thanks-Rob
Just make sure the loc you use.is powered or switched as you require.
Discussion Starter · #4 ·
Ok thanks
Are the empty fuse areas juiced if you insert the correct fuse? I just used one that already had a fuse in it and I made sure it was not associated with anything special.
Sent from my SAMSUNG-SGH-I747 using AutoGuide.Com Free App
Discussion Starter · #6 ·
I used empty number 23 and other people have said 23 is ok.
Excellent, I will check it out. What amp is it? I know there is a seller on ebay that has a fuse with a wire gage connector in it
yes used 23 because it's ignition powered. there are others that are the same. you can load it to 25A no probs!
Thanks AlienPrime!
Would this work? Minifuse
I also found something like this on ebay.
1 - 10 of 10 Posts
