I have a 2012 Honda civic. I am aware there are two fuse box. 1) under hood, 2) under dashboard.
The fuse diagram under dashboard matches with fuses; there is no problem. But the fuse diagram under hood (beside battery) does NOT MATCH with the fuses.
Anyone has any idea on how to read the diagram? Or I am too dumb to understand it : (
For example, I took out the fuse in the red circle (10 amp). According to the diagram, it is #4 for "L H/L LO" (Left Headlight Low Beam). However, after it was taken out, the low beam is still ON. My Multi-Information Display is OFF. Apparently, the fuse is not for the headlight.
Can any one help me to understand the diagram? Am I having a wrong diagram?
This is my first post. Thank you so much!
