Help CV axle passenger side
254 views 6 replies 4 participants last post by  EffBee6fromthe209
#1 ·
My cv axle wont come out. The boots were ripped both side I tried pulling and it came off leaving the end of axle stuck to transmission. I for the life of cannot get it loose . Use pry bar used hammer and screwdriver. Not aure what else to try. Thanks for any help
#6 ·
I got a chiesel and a small sledge and beat it at the cup, close tp the transmission. You probably got the retainer clip jammed. Your best bet if the chiesel doesn't work is a slide hammer with the vise grip attachment. Rotate and pull, hooefully it dislodges you will probably need a replacement is your new axles don't come with them. Harbor freight (9way) or other parts store.
