1 - 8 of 8 Posts
In 2012 Civic LX what would be easy way to reach out the low beam bulb? I almost cut my hands trying to reach out the bulbs :dancingcoolsmiley:
On a right side I can remove the battery but it's too much work...
How to reach out the left passenger side please?
I can't believe that in order to change the bulb something needs to be removed? Do you think that dealership changing the bulbs with all these problems too?
I believe it should be easy way to change the bulbs...:eek3dancesmiley:
Thank you!
On the passenger side you remove the top tube of the washer container by taking off the clip that holds it down. On the driver side you remove the intake air guard by removing two push tabs.
Thank you! Where that air guard on a driver side please. Anybody have the picture so I will remove the right piece ...
Discussion Starter · #7 ·
Thank you so much! I saw those clips but they look different and I was afraid to pull them out without braking. Thank so much now I can install my HID :wigglesmiley:
1 - 8 of 8 Posts
