1 - 8 of 8 Posts
okay so I have installed 3k HIDs on my fogs and they were an easy plug and play, but now I decided to also do my headlights so I went ahead and installed the 8k. I connected the passenger side first and it worked simple now I go to the drivers side and light will not turn on. I go ahead and switch ballast, nothing turns on for drivers side, then I decide to switch bulbs and still nothing, so then I decide to plug in the OEM lights and that bulb will not light. everything seems to work perfectly fine on the passenger side but once things are connected the driver side low beams do not go on. has this occurred to anyone, does anyone know as to why this happened? could this be I might of pulled the wiring harness a bit too much?
If the OEM bulbs don't work then it sounds like you somehow blew a fuse. Check the box and see if you did.
Sent from my Desire HD
Definitely blown fuse, this happened to me as well with some cheapo eBay HIDs, they worked fine for a couple weeks then the drivers' side fuse randomly blew
I'm using O-NEX HID Conversion Kit.
Discussion Starter · #7 ·
Check the fuse box and see if the fuse blew out. More than likely it did so buy a couple replacements and try installing again and making sure you aren't mixing wires around.
alright thanks man.
Just installed a Pair Of Xentec 6K with Mini slim Ballast.. Works Perfect. And Much Thanks For the Installation Pics...
1 - 8 of 8 Posts
