1 - 3 of 3 Posts
First post, take it easy on me.
I’ve had a 2013 si since December 2018. Upon tinkering with the car I noticed I was able to adjust my two step from my cruise control buttons. After research I cane to the conclusion flashpro was installed at one point
Although the car did not come with a flash pro box I assume flash pro was installed prior to me purchasing the car.
Today I bought a flashpro and every map I installed made the car run bad.
Here we’re some symptoms:
Looping idle
Rpms not passing 2.5k if I Hit the throttle hard
High idle
Idle sticking (after letting off the gas idle would drop past 1 then up to 1.5 then drop down
The car basically ran awful until I flashed back to stock.
Anyone have any insight?
1 - 3 of 3 Posts
