1 - 2 of 2 Posts
Supporting Vendor
Honda Civic LED Tail Light LEDs
Tail Light LEDs for Honda Civic (pair)
Brightness
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb compared to factory:
HP11: (310 lumens) Slightly higher brightness than OEM bulbs.
XP80: (510 lumens) Much brighter than OEM bulbs. These are bright!
Bulb Design:
HP11: Four side-firing 1.5W-rated Osram LED chips, and one 5W-rated LED chip on top, which is projected by a lens for maximum effective brightness. The bulb is housed in a machined aluminum casing, which provides superior heat diffusion for long life.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
Included in your order is TWO BULBS.
Flasher Replacement: Replacing the flasher relay, the module that controls blinking speed, is the easiest option to correct hyperblinking. You can remove the flasher on your vehicle, which is a small relay module under the dash, and replace it with a new flasher designed for LEDs. You will only need one flasher for your vehicle, whether you are replacing just one pair or both sets of turn signal bulbs (front/rear).
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty. For more information, please view the FAQ guide.
Click to order or for more information:
If you have any questions, please don't hesitate to post, PM, email[email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
1 - 2 of 2 Posts
