I cannot believe there isn't a writeup on this in 2021, but I found little info on this so hopefully this will help others. One of my biggest complaints about the 9th gen Si was the stock 7in display. For those that bought their Civics with premium audio in 2014, we were promised CarPlay and after the fact, they rescinded the rollout of CarPlay. Since then there really hasn't a lot of info or solutions too getting a seamlessly integrated setup that looks factory.
The setup I did retains all functionality, and I mean all of it. All steering wheel controls work, iMid clock changes with the head unit clock, backup camera and lane switch camera work when you put the car into reverse, or put the right blinker on respectively. Here is a list of what is retained:
1. 2013 Civic with Navi dash bezel. For the Si, you need the 2013 Si bezel as it is the carbon fiber version. The 2014-2015 with 7in screen will not be compatible with a double din head unit, it has to be a 2013 navi bezel. P/N 77250-TR7-C11ZA (for the carbon bezel)
2. iDatalink Maestro RR. This integrates the head unit to your car t retain all the factory accessories
3. iDatalink HRN-RR-HO2 integration harness. This is the harness that is pre made for our cars, so it saves you the headache of having to spice and make the harness
4. iDatalink USB2 adapter x2. You need two of these, as there are two powered USB ports in our cars. This simply allows the factory USB ports too function.
5. Metra 40-HD11 antenna adapter. This integrates the factory antenna to the head unit.
6. An acceptable head unit that can accept all of our cars features. This will be something you have to research and make sure everything is compatible. Crutchfield.com is a fantastic resource for this. I picked the Kenwood DMX957XR head unit and I really love it.
I added a custom splash screen so it really looks factory when you fire the car up. Overall, it is a big investment to get CarPlay but I am super super happy with it.
- Steering Wheel Controls
- SWC Made Simpler
- Amplifier
- Subwoofer
- Bluetooth
- Backup Camera
- AUX Input
- USB port
- Connections for DVD and GPS
- Added Onscreen Features
- Side View / Lane Watch
- Factory Vehicle Settings
