1 - 14 of 14 Posts
is it plug and play? or do you have to splice some wiring. i cant find a defined answer. is it something someone with very little car modding can do?
400 Club here I come!
Yeah no splicing needed if you just switch over the pins Inside the connectors.
n8vsi, how? our stock injector pins are to small... the 8th injectors are thicker and even if you put the pins in they would expand... i have tried this maybe i did it wrong?
Yeah, sorry I didn't update. The pins are too small that is correct. You need the pigtails. I tried to re pin that didn't work, plus I had the wrong clips lol. I had to get pigtails for RDX injectors.
Wrong! I put the smaller pins into the 8th gen clips, lined them up straight, and plugged in the injector. It works PERFECT... no cutting or splicing.
Yeah, sorry I didn't update. The pins are too small that is correct. You need the pigtails. I tried to re pin that didn't work, plus I had the wrong clips lol. I had to get pigtails for RDX injectors. Sent from AutoGuide.com Free App
How about no, and why would you act like I am being petty when your post was obviously obnoxious.
I jut get defensive and I did make my pins fit over the RDX wider pins but it warped the hell out of em. I just ordered some proper clips n pigtails
Wish rdx injectors were plug & play!
1 - 14 of 14 Posts
