1 - 12 of 12 Posts
So that’s not completely true, I understand how they work and the methodology behind them, what I don’t understand is how to purchase them properly. I’ve been looking at different kits (future purchase within the next year btw) but they are so expensive. Could anyone guide me through how I would go about building a custom turbo kit (like finding and buying all the parts and then taking it in to have it installed), I’m mainly looking for suggestions on parts, a list of the parts I need, and lastly prices. I’m trying to get the most bang for my buck, so the cheaper the better but I don’t want it to be a POS, lmk what y’all think I appreciate any suggestions, and like I said, complete noob to turbos =D.
P.s. my si is A sedan completely stock, I plan on getting a tune, cai, and some other basic bolt ons, but I’m trying to get a list together so I know how much a custom turbo would cost since it is the most impactful mod I could realistically do. (Don’t want e-85 rn because of how quickly I burn through gas)
I think you're gonna find that 99% of turbos people on this forum use are the kits. If anyone had the time and money to cobble together a new functional turbo setup from scratch, they'd probably start selling it as a kit, or they should if they were wise.
Full disclosure, I have no personal experience with turbos, kit or otherwise, so this is just my perspective. Save up for a kit. Trying to piece something together could end up being more expensive and/or dangerous. On the other hand, it could be a cool and fun project that may or not get completed, but be sure to take pics.
my past experience, piecing together a turbo kit isnt that bad. the real pain in the ass is all the lil stuff, clamps, oil/coolant lines, hardware etc.
kits are nice cause of the instructions, customer support and everything is in the box (usually).
i have cai, catless dp, hondata and etune.
if i were to do it again, i would have just put the intake and dp money towards forced induction.
i was gonna go ct blower but they pulled the pin.
I did a full race kit last winter. It's nice, had every hose, clamp, oil fitting needed with good instructions. Only thing needed outside the kit was spark plugs and clutch I believe. I went with the full race, because the Borg Warner EFR turbo has a internal waste gate. *Edit* this kit also came with injector Dynamics injectors. Highly suggest not going cheap on the injector side.
I probably could have gotten away with purchasing a tig welder, and making my own intercooler pipes, and downpipe. Im sure money can be saved by shopping around, and making some stuff yourself. I don't have a tig welder, pipe die, so it was easier to buy a kit.
In reality, you have to buy a intercooler, turbo, manifold, oil feed line and fittings, oil drain fittings, hose clamps, injectors, intercooler couplings. That's where the kit is just easier.
But thing is, I plan on taking it to a shop to have it installed so ease of installation isn’t too much of an issue, I’m just wondering an estimate price and what parts I need so I could take it to a mechanic
meant to post it to here
Search this on YouTube: Budget Turbo Kit, Gives this 2015 Civic Impressive Gains
This guy made his own turbo kit. Maybe hit up him up. He commented on PFI's YouTube page as Thomas Davis.
If your not doing it yourself, I can't see it being cheaper to pay labor hours for fabricating all the plumbing rather than buying a kit. As you said, ease of install won't be a problem for you, but that means more labor hours at around $130hr. YouTube builds are not realistic, no one wants to watch a guy fight a rounded off bolt.
I installed the full race kit myself. I had the tuning shop fabricate a battery tray, look over everything, do the first start, and tune. That alone was well over 3,000. If they had to fab up everything there I couldn't imagine the cost. Unless you have a buddy with a Dyno, or your going low boost and no intercooler, I'd budget no less than 10k to turbo with you not touching the car. If you order a kit, total parts tend to be around 8k if your going for 350hp+.
There's kmod performance that is really cheap, but you'd have to live fairly close. He quoted $8700 installed and tuned a year or so ago, keep in mind he's done several 9th gen turbos so can keep labor time down.
Outside of that, I recommend the centrifugal super charger. It's cheaper, can make 400hp, and labor for install will be much cheaper.
You should talk with said shop about their recommendation and of they are willing to take on the install. As another member said, be prepared to spend some $$ on labor if they have to end up fabbing something or sourcing parts.
The only way I see to save money on a custom kit is to buy used and DIY the install.
Keep in mind that the manifold you use will affect downpipe and intercooler fitment. This is why using a kit can be a benefit. You will at least need a "hot parts" kit to get started.
yea, cutting corners and budgeting isn't the way to go when force inducting a car (I know from personal experience when I was younger). You gotta pay to play. Even my supercharger build has me pushing close to 8k+ right now. You have to consider all the other things too: clutch, injectors, aftermarket ECU, tune, fuel pump, fuel return system, tires, etc. It ain't cheap. A kit gives you a baseline and proven system.
1 - 12 of 12 Posts
