1 - 4 of 4 Posts
Hello, I just replaced my Original idler pulley and belt with a gates on both. The new belt seems tight but the pulley is making a noise again. The same noise from the old one. Could something have made this new one go out so fast or was it just a junk part? Also what are the torque specs for the pulley?
Did you replace the tensioner as well. Is the belt tensioner properly?
You can use this guide to check
Thanks for the diagram I’m actually gonna print it. The noise went away and the belt is tight so I guess everything is fine. Now I just need some shocks, my steering has been rough and found out today the mounts are cracked.
1 - 4 of 4 Posts
