1 - 19 of 19 Posts
I recently installed a set of function form type 2’s on my 2015 civic si sedan and now I’ve got a front strut noise going over bumps. I checked the strut tower bolts all tight. It sounds like it’s coming from the top hat. Can u tightened the nut below the stiffness adjustment knob?? All signs are pointing towards the top hat. Also notice their is white stuff around the base of the strut tower is that normal?
Did you preload the springs?
No I didn’t. The noise definitely sounds like something is loose but it’s not a metal sound.
The center nut on the strut needs to be torqued to spec.
The top hat has got white stuff forming around the center nut underneath the damper knob is that the lube for the strut?
Can u take off the adjustment without messing anything up?
I'm not familiar with those specific coilovers but I would think the knob would just pull off the stem of the strut. Then you will need to find a way to hold the strut body while you torque the nut.
Usually some type of pass through socket or some people will hit it with an impact
Discussion Starter #9
I appreciate the info.
Function told me there needs to be at least four threads showing a live the center nut. Something definitely sounds like it’s loose
Ok...did you torque the nut down yet? You don't want to drive around with a loose strut...
Discussion Starter #12
I haven’t yet. I’ve had several people tell me different things. Do I need to take off the damper knob to tighten the nut down? Function is telling me they don’t recommend torquing it just as long as there is 3-4 threads showing. I don’t want to damage anything by driving around with it.
How would you know how many threads are showing without removing the adjustment knob?
Can you post a picture of the top of the coilover with and without the knob?
Discussion Starter #14
492137
Does the knob come off? You can't see the threads on the top of the strut with the knob on there.
If you don't want to mess with the knob, can you at least use an open end wrench to see of you can tighten the top nut?
1 - 19 of 19 Posts
