21 - 23 of 23 Posts
Discussion Starter #23
Just an FYI for people putting skunk2's rear camber arms on, don't forget to run the adjustments all the way in before mounting the camber arm. Once you got the camber arm bolted in you can go about adjusting it to proper alignment. There are left hand and right hand threads on these adjustments and the adjusters can easily get out of balance if not careful. This is why I recommend adjusting them all they way in and mount the arm then adjust the camber out to have even/proper adjustments on the adjusters.
21 - 23 of 23 Posts
