41 - 60 of 122 Posts
i dont know about how to remove but i do know tht it will effect your warranty. if some happens to your car like the engine comes on and they find out that you resonator is missing, even if it has nothing to do with the light being on they will not fix.
It won't affect your warranty but you may find that your dealer says it will. There are no moving parts on the resonater so your check engine light won't come on.
Sent from my GT-P7510 using AutoGuide.com App
that cranky admin
That's not what the law says :police:
thanks for the advice guys!
very much appreciated!
i dont thinik ill go with it then, my father probably won't do anything that'll effect the warranty :(
Removing the resonator will not affect the warranty and it will most certainly not throw a cel...give me a break! Its only there to keep noise down.
Sent from my DROIDX
With the LX (r18) I have found that one of the best ways to do it is to leave the first piece of piping on the box (the one that goes downward), and justget a flex tube or something to go down to the grille. I mean, there is automatically less restriction without the resonator, a few extra feet of hose wont hold anything back. Also prevents too much noise....
That sounds wierd, ik, but i originally took ALL of the piping off and just left the box with an opening on it, but the sound was so loud, yet muffled, it was awefull. But the farther the tube is away from your motor, the cooler the air, and as long as its an open tube, the sound will be perfect :)
i kinda wanna do this.. if someone can help PM me thanks
400 Club here I come!
Looks like a simple modification, it will make a little bit more noise when you step on the throttle, and possibly could yield a little bit better performance? I might try this along with a k&n at least until I decide to buy myself an intake... You can get at it from the wheel well I read if you remove the liner. One bolt holding the resonator in place
Here is a vid of a guy that did it. He has an R18 as well I believe.
Sent from my iPad using AG Free
That's an Si bro
Brought to you by the one and only Kid Jdee
FB2 squad #17
That's an Si bro
FB2 squad #17
Oh yaayyyy, I looked at a vid for what a running time of 1 min, I am trying to give this guy some help, and a ll you can say is,"that's an Si bro"? LOl come on man.
Well I pulled off my resonator this morning and it took me about 15 mins. Jacked up the Si and unbolted two 10 mm bolts and separated the plastic pieces... You might or might not need to have someone pull up on the upper half, I did because my arm barely fit and I didn't want to break anything, but you won't and the piece comes right out of there as well....
The op has a EX civic different setup
You have an SI, the video yu posted was of an Si. The non Si models are different from Si models bro
FB2 squad #17
so you can just pull it right out also its located inside the pipe between the exhuast and cat
