181 - 200 of 1140 Posts
Downhill specialist
Yes that rattling with annoy you. If you're tight on money, just saw off the metal piece that is hitting. Other than that, it's an incredible exhaust! Highly recommend it!
Invidia q3000 Rattling issue solved with the skunk 2 alpha header I think it's caused by the restriction from the two cats but now it's solved. If any else has problems when idling with ac on get a alpha skunk header. Problem solved..
So after you installed the skunk2 dp. There was no more rattle at all?!
Does anyone know where I can purchase stiffer exhaust mounts? I hate the rattling noise too
i have the invidia q300 and it rattled like crazy until i got stiffer exhaust mounts, and now thank god that problem is taken care off!
Where did you buy the exhaust mounts?
I just put my q300 on two days ago. When i first started it it was constant rattle the muffler was hitting a brack i guess u can call it where the hanger is i took off the muffler and got a grinder and grinded down the rolled metal on the very top front and i grinded the bracket alittle and now there is no rattle everynow and then i can here it a little but it pretty much gone. And ivwas aldo thinking of getting those mounts also
Downhill specialist
I did the same as well, but I think Invidia moves up as you drive which cause slight rattle barely even noticeable and settles down when you turn off the car.
All I know is,mine got worse over time,a lot worse.It was to the point of rattling during gear changes and uneven road surfaces,very annoying and I would even say embarrassing because I'm sure it could be heard outside the car.
me too, i'm throwing my stock axle back on to get rid of it for a while until i fix it. It is constant now that the exhaust has been on for almost 2 months
Ditto. Mine is the exact same way. Like when I'm in 3rd and I slow down to under 2k rpm, it'll rattle really bad. And even through gear changes. It's really starting to ******* piss me off. I hear rumors that people with the Skunk2 dp saying it fixed their rattles...I'm getting the dp very very soon so I'll see if that's true or not.
Im glad the exhaust mounts i told you about worked. Def worth the $45 imo. Sounds great now right?
invidia q300 installation
hi peeps to all who did DIY ( installation Q300) did you use all the bolts? what did you do in the (downpipe) with 3 bolts did you use the oem bolts? cant remove the oem bolts (downpipe area).........:(
I just left the bolts on the cat i couldnt get them off. i still had some bolts left over that came with the q300 been on a week no problems.
Raspy is a bad thing?
Just ordered the N1 from TopGearSolutions.com. total price shipped 486.95. Currently on sale if anyones looking to buy right now.
