1 - 20 of 29 Posts
So we all know of the Hybrid Racing, Hardmotion and other EM1 CMC kits for our cars. They work ok for the most part, and I had actually installed my Hybrid Racing EM1 CMC, and removed it several times to compare to the stock CMC for comparison purposes. I ended up liking the feel of the EM1 CMC as far as clutch feel but I hated the idea of mixing and matching parts, the rod didn't mate correctly to the piston inside the CMC, and there was a bunch of vibration in the pedal, as well as a crunchy feeling when engaging the pedal because of the different shapes on the mating surfaces of the rod, and the piston. I was going to live with it until K-Tuned came out with a CMC kit for our cars. The major difference in this kit is that it is a CMC designed by K-Tuned. It isn't an OEM CMC that has to be modified to work correctly or anything like that. It has better than OEM internals (metal piston etc.). I finally got around to installing it today so I thought I would chime in on it. Clutch feel is very nice with linear engagement. The pedal is extremely smooth with no crunchiness. Most of all, no pedal vibration! I had used the Hybrid Racing SS clutch line with both the stock CMC and the EM1 CMC and I noticed a significant difference in vibration with the EM1 CMC, so I am glad that there is no pedal vibration.
Box it comes in:
From left to right: stock, Hybrid Racing EM1 kit, K-Tuned
Closeup of the K-Tuned unit
The other kits on the market shouldn't even be in consideration anymore. The K-Tuned CMC is a direct bolt on replacement that deletes the diaphram, has better internals and will make shifting feel much better.
Thanks for the great review brotha!
I feel my self stupid here guys.
what is CMC stand for ? lol
Been thinking about buying the whole cmc/slave cylinder kit, how bad is it getting the cmc's in and out of the car? Looks like a pain to get up in the firewall.
Not hard at all, but I have taken CMCs out and installed them again a million times on my car. But it isn't hard. The only thing that makes it hard is if you have the stock airbox.
I installed mine yesterday. What a difference! No more slow and vague clutch engagement. The car finally feels as it should be. I did the CDV delete last year, i strongly recommend everyone to do those two mods.
In terms of installation difficulty, I personally found that it was a PITA because of the location of the CMC. The access is very tight but its doable with patience.
Couple of questions for you two:
1. Where did u buy this kit?
2. Is the swap easy as taking the old part out and putting the new part in? Or does some of the stock internals from the stock part needs to be put back in the K-tuned kit?
Thanks.
So the main purpose of this mod is to have a smoother clutch feel? I feel like it's smooth already. Are there any other benefits?
Thanks.
1- I got the kit directly from K-tuned website.
2- You do not need to switch internal parts like the Hybrid racing kit. The only thing you need to re use is the ''clevis'', the U shape part that bolts at the end of the rod. Fits perfectly.
The idea is not to make it smoother, its to allow the clutch to grip faster. The feel in the pedal is positively impacted as now you feel the engagement much more precisely.
Discussion Starter #14
Where did you read that you had to reuse the clevis from the stock cmc? I emailed KTuned asking them this specifically and they said it was 100% bolt on for the 9th gen so that's what I did.
I saw that it requires switching the clevis too, on their website. See below,
Also, did you buy the slave cylinder or just used what you already had (stock) ?
On their website they say to use the stock clevis for 2012-2015 Civic and I confirmed with Mike from K-Tuned.
Ever since I bought the car it seems like I almost have to ride the clutch a little bit to take off in 1st... anyone else experience this? Will this CMC kit fix that - make the engagement quicker without having to use up too much clutch?
Discussion Starter #20
The EM1 makes it engage quicker. Although stock, EM1 and Ktuned you don't have to ride if you rev before letting the clutch out in first. Of all the CMCs I have, the EM1 has the shortest engagement.
I ordered a modified stock CMC from K20z3AllMotor, so I will probably write up a detailed piece on all the master cylinders.
1 - 20 of 29 Posts
