1 - 12 of 12 Posts
· Registered
You're in the Honda world baby ANYTHING IS POSSIBLE!!!
all jokes aside, yes its possible but its not a straight drop in. If I'm not mistaken the biggest issue in terms of getting it to physically fit in the engine bay is the exhaust header. The K24A header is a 4 port, the original 9th gen Si engine (K24z7) has a singe port exhaust. So you're going to have to get a custom one made, buy a custom one pre made (only seen one and it was stupid expensive), or do what I've seen others do and bang the 4 port exhaust header with a mallet to make it fit / clear the firewall. I know the placement of the oil filter is different on the K24A as well, but I don't think that's an issue as its common to relocate it to that same spot on the K24Z to run different oil pump setups that require an adapter.
now for ECU/electronics and all that you could get it work just fine but you'd have to have a ktuner or flashpro to get everything to work correctly. This is almost certainly something that has been discussed in depth @ K20a so I would search over there and/or ask around, a lot of super technical guys over there
· Registered
2013 Civic Si Sedan
Discussion Starter · #4 ·
I'm not familiar with other K series motors, but what would be the benefits of a K24A motor compared to our stock K27z7 motor? :)
I’m not completely sure but my motor is done for and a lot of people swap the k24z3 or k24a because they’re practically the same motor, some even say it’s better but I don’t know any truth to that
· Registered
2013 Civic Si Sedan
Discussion Starter · #6 ·
Could you link me the exhaust header that would work. Been looking for one online and can’t find it. If not i guess I’ll have one made
· Registered
I believe the k24a was the one in the TL that has vtec on both intake and exhaust side unlike our z7.
You would need an aftermarket exhaust manifold or a 4 to 1 connection and some custom piping from there to the catback.
Oil filter might be relocated and you can upgrade to the type s oil pump too.
It pretty much drops in otherwise using the same engine and trans mounts
· Registered
2013 Civic Si Sedan
Discussion Starter · #8 ·
What’s the power differences? Also yeah I figured I would need a custom exhaust mani but I can’t find one online. Should I just get one made or do you know of any?
· Registered
I think the compression ratio is smaller than our z7. A boosted z7 will make more power than a boosted a4.
It’s more of trying to get the car na maxed out that people do the swap.
You are better off doing a head swap on the z7 if you wanted to stay na
1 - 12 of 12 Posts
