1 - 9 of 9 Posts
I have a 2012 Civic Si Coupe.
The key does not want to go into the handle all the way nor will it turn.
I have tried lubing up the cylinder with no luck.
Any insight on this will be helpful.
Thank you!
I have the same issue. I just assumed some schmuck was in there with a screwdriver. If it's something else that can be resolved more easily than having it replaced, I'd like to know, too.
I had the issue before freezing temps.
It does not appear to have any signs of tampering from thieves.
I have used locksmiths lube with no luck.
Looks like I might have to take it apart or have the dealership replace.
Ditto on all points.
If its frozen, auto part stores sell lock de-icer with is basically a small can with alcohol with a tip to go into the cylinder. worked for me.
Discussion Starter #8
It is okay Shoran0603. Reading sometimes owns me also. haha
I have not had the time to tear into it as it is winter and no time to do so.
I just would like to lock my car while it is running to warm up in the cold weather.
I will just have to sit in a cold car while it is warming up hahaha
1 - 9 of 9 Posts
