I looked through a bunch of forums for comparison threads but I haven't been able to find anything on which ones are the best for ride quality/durability. I have a 13 civic sedan. Im looking into doing it in spring 2014 as well as throwing on some enkeis (17-18"). I dont want to slam it, what do...
I cannot tell if there will be rubbing in your particular case, but I can tell you that wheel spacers have been used by members to move the wheels outward anywhere from 5 to 20mm.
Personally, I don't like the 5mms because they move the wheel off the hub and put all the pressure on the lugs. The 15s and 20s I have seen all have a second set of studs so that that the hub takes the brunt of the pressure, as it should.
Either a more narrow wheel or higher offset wheel will avoid rubbing.
Also you already mentioned going back to a 225/40. That will help as well.
Other option is to add camber to clear.
There is a huge wheel fitment thread, check that out for lots of examples.
Related Threads
9th Gen Civic Forum
720.8K posts
39.3K members
Since 2010
