1 - 9 of 9 Posts
Blues Clues
LX Bolt Pattern and Offset
bolt pattern and offset of stock lx ex wheels? any suggestions on rims? thinking of work emotion cr kai's.
I guess I need to do some research, but prior to gen9, an lx had 4 lugs and an ex had 5 lugs. Correct me if I'm wrong! Are they all 5 lug in 2012?
2014 January FB2/FB6 ROTM
yup, my LX has five :)
Blues Clues
Discussion Starter · #6 ·
thanks a lot. felt kind of dumb asking this question. this is my first civic!
Car Care Ambassador
These rims look pretty good. What do you guys think? Will they fit? the tires on them are 215/45/17. Would they clear?
Bronze 5zigen ZR+ 17x7 5x114.3
Should fit, I just put 17 x 8 on mine with 225/45/17 on them. The offset of 47 is a little low which might put them in a little ways further than stock.
The tires are a concern to me, they will be garbage as they are a mismatch and thats something you DON'T want is a mismatch. You would have to try and buy 2 new ones to match the good ones.
I know who U R.
Im putting new wheels on my 13 coupe and want to put the EX wheels on my 2014 CR-V I know the bolt pattern is the same and it has 16" rims same as my Civic.My question is what is the offset of the stock EX alloy wheels?Edited^^^^Ok I am adding that after searcing I have come up with the stock wheels are 45mm offset and the CR-V has a 50mm offset.So instead of deleting this post Im offering the info I found for future inquiring.
Reactions: scottyrocks
1 - 9 of 9 Posts
