1 - 10 of 10 Posts
So I did a retrofit on my civic back in October, it was running great, loved it. Now they are freaking out and the hids will just occasionally go off while I'm driving, which is kind of bad :/
I know it's not th ballasts because they will go off at the exact same time, any ideas?
I've taken a voltmeter to it though, and it all registers just fine, and te connections all seem secure
Morimoto I believe got them from thereteofitsource
my morimoto retro fit in my wrx did the same thing....the connectors needed some adjustments by bending the terminals a little for better contact...idk though you said yours are fine...
Discussion Starter · #7 ·
So I sat there and wiggled every single wire in the harness, foud the issue, one of the power cables was soldered horribly, did a temporary fix and now trs it sending me a new harness
Did you install relay harness with it?
Discussion Starter · #10 ·
Yeah the harness had a faulty solder point
1 - 10 of 10 Posts
