1 - 5 of 5 Posts
So I plugged in my after market stereo with the harness and everything worked and turned on but my volume is too low and it turned all the way up I have a honda civic ex 2012 with factory amp what can I do to get more volume ?
Sounds like the factory amp is holding you back. Time to upgrade to a new amp.
The factory amp is setup so it won't overdrive the speakers. An aftermarket amp can and probably will blow your factory speakers.
I heard phantom audio is a good upgrade.
Con confirm. Jesse over at Phantom can work wonders on the stock amp. Takes it apart and replaces all the internals. There's a long thread on it here in the audio section. I'd do it again if I had to.
1 - 5 of 5 Posts
