Personally, I love the way each of wheels look. Just can't narrow it down... Weight is not really a factor. On the XXR, I'd like to know if there would be a clearance issue with a 35mm offset.
Sparco Terra
17X7.5
45mm offset
21lbs/rim
Enkei PF01
17X8
45mm offset
17.2lbs/rim
Enkei RPF1
17X8
45mm offset
15.6lbs/rim
XXR 531
17X8
35mm offset
weight unknown
Sparco Terra
17X7.5
45mm offset
21lbs/rim
Enkei PF01
17X8
45mm offset
17.2lbs/rim
Enkei RPF1
17X8
45mm offset
15.6lbs/rim
XXR 531
17X8
35mm offset
weight unknown
