1 - 8 of 8 Posts
Hey all, I recently purchased a 2014 Honda Civic Si and I was putting on back the original air intake in order to do a SMOG check here in California. I realized that the previous owner did not include this last hose needed to put everything back together. Anyone know the name of the hose and the part number? Thanks!
I believe you need #3 and #4
#3 connects to the rubber intake boot.
The rubber hose from the head connects to the metal tube.
491089
Go here:
F/F to minute 5:52 and you will see what item #3 is for.
Depending on the inspection station person.
They may or may not fail your car for not having item #3 in place.
just curious if it is part number #3, why does it have two openings on each end?
This is a hard pipe, one side is the pvc vent, the other is coolant. You can see in your picture, there is a small coolant hose with a bypass union from where the hard pipe was removed.
What I would do is get a 1/2" (or 3/8" maybe?) plastic straight with a piece of rubber hose to connect to the valve cover.
Connecting the valve cover breather nipple to the air intake pipe with a plain tube will not pass the underhood visual inspection.
The engine has to be 100% stock in appearance to pass the visual test.
Dang, I just threw one of these away.
And that's why we hoard... I was looking for a banjo bolt the other day. Found one in my misc screw drawer. Most of which is probably older than a good percentage of the people on this forum.
1 - 8 of 8 Posts
