1 - 1 of 1 Posts
I got a 2014 Civic LX, automatic (sadly), wanting to start building it up..
One, without doing a full turbo kit do you think I can push out same hp as the SI. If so what do you think I should look for in upgrading?
Note, just installed Private Label MFG header, full Yonaka exhaust, and cold air intake (actually plated off with heat shield, not just an cone filter like many people do). My plan is to get flashpro, two stage cam, higher flow injectors, and maybe throttle body. Any other suggestions or recommendations for parts or if anything I mentioned is worth it or not?
Also want to upgrade suspension,nothing too fancy, just something that takes turns better since I drive over curvy mountains a lot, but want to try and keep it as close to stock height as possible.
1 - 1 of 1 Posts
