1 - 8 of 8 Posts
My passenger side HID ballast dropped from where it was mounted and got sliced somewhere in my engine bay. or something like that.. Long story short.. My hi beam no longer works on that side. I've only worked on Chevy's and am not sure where to start checking fuses.. or if that is even the problem. any ideas? i'm in a hurry at the moment ill post more detailed things later.
Thanks
Did you ever get it fixed? If not, there are two fuse boxes: one under the hood on the right side, and another under the dashboard on the driver's side on the left. Both have diagrams as to which fuse goes to what. Just look for the one that says "High beams" or abbreviated to just "Hi". If the driver's side high beam is still functional, it doesn't sound like a fuse problem, but never hurts to check. Can you backtrack from the high beam hole to where the HID light plugged in and the cable backwards to the stock assembly?
1 - 8 of 8 Posts
