1 - 3 of 3 Posts
Ok, a friend of mine and I installed my KW SC kit. It requires a battery relocation to the top of my engine bay. I believe that negative charge was touching the top of my engine bay when I turned ignition. When I turned ignition as it should my car responded with lights and imid screen, then seemed to die. I tried to crank it up and nothing, lights inside the car didnt work, it didnt turn on, even my key to open trunk didn't open trunk.
Could I have drained the battery out? What else could it be? Everything else was plugged back in before i tried to turn on, except fuel injectors which werent plugged in cause I was adding oil to my rotrex, which in directions requires them to be out. When we tried to take the battery out, it made a little spark.
Any ideas what happen?
Thanks
1 - 3 of 3 Posts
