1 - 7 of 7 Posts
I have a 12 ex 1.8L. I notice today while checking my brake fluid. Under air box near trans dip stick. There is oil pooled up. I took picture. It will be attached. Its oil not trans oil. I cleaned area and will check tomorrow after work. What could it possibly be?
Thanks
493544
Photoshop Masta
Thanks View attachment 493544
Did you check your brake fluid just cause or cause you've been noticing it was low? Could that pool possibly be brake fluid?
Well I just did front brake pads level is on mark . Ill check master cylinder.
Discussion Starter · #4 ·
Not brake fluid. I cleaned area off with brakeClean And oil comes back. I guess my next day off ill pull airfilter box off and see where oil is coming from.
I took airfilter box up and I can't find oil leak. I see oil but its pooled up. I cleaned all the area. Maybe oil is all over engine from spill. Where would the main rear seal leak. I am used to chevy v8 not civic. Is there inspection plate on driver side that maybe jacket went bad ?
2015 Honda Civic Si Coupe
If the rear main seal was leaking, there's no way it would make it to the top of the trans.
Discussion Starter · #7 ·
Well I found a gasket it might be. Just got to figure out how to replace it. I think its called camshaft thrust o-ring. On driver side.
1 - 7 of 7 Posts
