1 - 12 of 12 Posts
Looking from front. On passengers side in rear of motor it is dripping down. I have checked the valve cover gasket no leaks from there. I have a 12 ex 1.8l . Does the newer 1.8l have a vetch solenoid?
Hope to hear from you all soo.
Without pictures this is going to be impossible to say.
Best way to find a leak it to totally clean the area and then inspect for fresh oil. Or add uv die and inspect with a blacklight.
Discussion Starter · #7 ·
Not really sure I followed ala around the valve cover cant see it leaking from there. I cleaned up it was all oily in that area and dripping down. I took picture after I cleaned. I have 191k on car and have never done valve cover. So I bought new gaskets with spark plug holes and honda bond. Just to do in case.
sure it's a leak? like is there a spot on the garage/driveway that you can see? could have been just residue oil from filter changes, oil fills, etc.
Discussion Starter · #10 ·
I cleaned area thinking same thing. It came back slowly. No drip on driveway. I have skid plates underneath. It was on skid plate. I just changed the valve cover gasket. Has never been change since new.
Discussion Starter · #11 ·
Well now leaks back. I just noticed a leak on the ground. Here are some pics. Paseenger side rear on motor by serpentine belt. I have seen before about inspection plate leaking and the the vetec solenoid.
493026
493027
493028
1 - 12 of 12 Posts
