1 - 20 of 20 Posts
Any imput on whats a good clutch for a turbo set up.
I understand i need 8th gen flywheel, and clutch to fit my 9th gen si. J
just want some real feedback on whats good, what crap.
ACT.... I swear by em. I never had any issue with them. They may be more money compared to Exedy or Competition clutch. But I know ACT works for sure.
Did you boost your 9th Gen!?!?!?!?! :D
No not yet getting everything ready before I slap the turbo on, which friction plate and pressure plate would you rec for about 400 hp 330 torqe
can we use after market flywheels? i think i read somewhere that you couldnt for some reason... can anyone chime in?
I've also read that a Lightened flywheel will trigger some sort of CEL light. Which code I don't know. But I do know that the trigger will put the car in limp mode.
Just stick with a stock unit until more light is shed on the flywheel issue.
The ACT-XGT6 will hold the power your looking for.
Discussion Starter #10
i've also read that a lightened flywheel will trigger some sort of cel light. Which code i don't know. But i do know that the trigger will put the car in limp mode.
The act-xgt6 will hold the power your looking for.
sent from autoguide.com free app
the cel issue is not a problem you can disable it with hondata, the cel light is for misfire detection. No biggy!
Where can i get an act clutch for a descent price
PRL seems to love their CC Stg4 Clutch with OEM8thgen Flywheel...
Procivic carries ACT and Competition Clutch. If I had to choose out of those two, my preference is ACT and I would select the performance disc because I want a full face w/springs. I also would upgrade the flywheel as suggested so I don't have to get the stock flywheel turned.
Turned is like the brake rotors when putting new pads on, they take a layer off to ensure it is not warped, out of round, and able to seat the new clutch disc.
Discussion Starter #16
procivic carries act and competition clutch. If i had to choose out of those two, my preference is act and i would select the performance disc because i want a full face w/springs. I also would upgrade the flywheel as suggested so i don't have to get the stock flywheel turned.
stock flywheel dont fit the performance clutch, 8th gen flywheel must be used.
i just checkedmy flashpro no where does it have a place to just disable anyrhing..
1 - 20 of 20 Posts
