1 - 7 of 7 Posts
Discussion Starter #2
If you use earlier model cam gears you can use any k-series cams.
The cam gears listed here wont really do anyone any good. From my experience adjusting the exhaust cam does very little. It's mostly used to correct the center line if the head or block have been milled.
Ohhh ok ok earlier models sweet, well cam gears usually are more effective when u have aftermarket camshafts :)
Sent from AutoGuide.com App
sorry.. you can use the earlier model cams with the earlier model gears. The previous generations of k-cams were a different length and use a different "offset" on the cam gears than the k24's with the single exhaust port.
This motor isnt anything new.. its been here since the 08 accord and 09 tsx
1 - 7 of 7 Posts
