Whatever, troll.20,000 and 150,000 miles thats recommended for replacing fuel filter check on your manual ..
So you're saying that the first fuel filter change is at 20k miles and then the next one is done another 130k miles later?20,000 and 150,000 miles thats recommended for replacing fuel filter check on your manual ..
So I`ll just change oil and i`m good, thanks.There is a filter but it’s not the small bottle sized one anymore. It’s a pretty big. That is also not a serviceable part. If you’re getting large debris stuck in it, then you have other issues going on with the trans since it is a closed system.
I'm in the middle of Eurasia@Fantastical_ , are you in eastern Europe?
"ATD DW-1" is the specification for the transmission fluid (measured viscosity at selected temperatures, choice of additives packaging, and so on).
If it says "ATF DW-1" and it's from Honda, it doesn't matter if it come in a 4L metal container or individual 1-quart plastic bottles. It's the same fluid. 👍
OF
