1 - 20 of 23 Posts
I need some of your help. I have a cel light last night. I scanned it came up at po420. I have had this in other cars but not familiar sith Honda's. Its a 2012 civic ex. 1.8l 150k. Hope everyone can help me.
Google shows o2 sensor fault. Might be time for a new cat. If its not too much trouble i'd pull the sensors and clean them see if that helps first. I've had cars throw a code because of dirty sensors.
Someone can correct me if I wrong, but that code can also throw for exhaust leaks. Although, at 150k it might simply be time for a new convertor and sensors.
Thank u for the screen picture. I have a scanner that just shows me codes. If. I clear the code then do test like picture says abd it comes back. I need to replace converter?
That's what the trouble shooting says... but I suppose it could be the down stream o2 sensor too. I have little experience with fuel and emissions problems.
I would call a local dealer or trusted mechanic and ask if they see many cats needing replacement at 150k miles?
Or is that 150k km?
Or is that 150k km?
150k yes cats can start to go.
I'd replace the O2 sensors with some quality sensors before jumping on the cat. 150K seems a bit early to me....
Discussion Starter #15
I put two new sensors in cleared the cel. Just waiting to see if code comes back. I have dont 3 drive cycles and 65miles. I will test more tommorrow when i head to work.
I’m glad it worked out for you. Keep us posted!!
Discussion Starter #19
Well i thought it was fixed. 3k of Miles later code is back. I hate to just throw parts into it. Should i change the cat? What should i do. I flashed system goes out for maybe a day.
1 - 20 of 23 Posts
