1 - 3 of 3 Posts
Hello everyone. How y'all doing? I'm kinda new so i don't know what info i need to provide but i'll do my best to describe my problem.
My switch wire (BLUE WIRE) to automatically turn on and off the amps/subs doesn't have a fuse ,and is directly connected to a fuse slot. The switch wire is connected to the fuse panel instead of tapping into the radio because the radio is stock and really hard to remove. Do i need a fuse for the switch wire? If yes, what kind of a fuse do i need to install for the switch wire. I need assurance and peace of mind because i am going crazy because of this problem. Thanks in advance, y'all.
Also, all of the audio equipment is safely fused except that switch wire. Where should i tap the switch wire instead? Another fuse slot?
You really ought to use the radio "accy on" for the amp Remote signal (even if it is a pain in the az to get to). That wire pulls way less than 1 amp so you really don't need an additional fuse.
1 - 3 of 3 Posts
