I was just poking around my Si & noticed the rad & fan assembly moves around... is this normal?
Normal, if it was bolted in tight road vibrations, pot holes etc would eventually crack it I believe.
Hey folks, I have a 2015 Honda Civic Si. One of the bolt washers that connects a fan to the radiator broke in half while we were attempting to remove it. So now, we have a broken bolt washer stuck on the radiator. I already have the replacement bolt washer. The broken one that is stuck on the radiator is protruding so we did attempt to put some WD-40 on it and try to grab it with a tool and turn it out but it won't budge. are two pictures. Also, when I tried searching for the other piece that the bolt washer connects to, it seems that isn't sold separately, it seems that it's part of the radiator itself and not sold separately. Any suggestions on how to get this broken bolt washer out?
Thans!
493186
