1 - 10 of 10 Posts
Should I be using something else other than the stock intake tube? or will this be ok?
You Don't know Me!
as long as it is clamped tight.
If you bought a silicone hose that was smooth it might flow a bit better. But someone else did this and it worked just fine
Sent from AutoGuide.com App
Discussion Starter · #6 ·
is that the silicone hose?
Which red throttle body spacer is that? It looks like the P2R spacer....but doesn't the 9th gen TB need an adapter to properly bolt onto the RBC?
1 - 10 of 10 Posts
