1 - 1 of 1 Posts
Vendor
Upgrading your OE headlights with bright LED bulbs is a smart move, as they will improve the light output and make your car look up to date. In today's write up we’ll take an in-depth look at the recently-released 2Stroke 3.0 LED Conversion Kit designed by Morimoto.
This high-quality automotive lighting product is engineered to boost up your visibility, thanks to the built-in high-performance Osram Oslon Black Flat S (KW HKL531.TE) chips that produce a pure white 5500K light output.
Morimoto - 2Stroke 3.0 LED Conversion Bulb (5202, Pure White)
Specifications:
DRL drive input range: 6-9V
Normal drive rate: 790mA
DRL drive input range: 250mA
Peak Lumens: 2,600lm
LED chips: Osram Oslon Black Flat S (KW HKL531.TE)
Includes:
(1) 5202 2Stroke 3.0 Series LED bulbs
(1) 2S3 LED drivers with DRL drive
5202 plug n play inputs
Features:
  • Superior beam quality
  • Optimized focal length
  • 360 degrees of rotation
  • Thermal management
  • 3-year warranty
Find out more about the latest Morimoto Release in this write-up.
1 - 1 of 1 Posts
