1 - 4 of 4 Posts
I kinda hate the look of the decklid spoiler on the Hybrid 2013. Also hate the wheels that I want to switch out with larger 16" OEM Honda Civic 2013 EX-L wheels (Hybrid wheels are only 15"), but I'm wondering if removing the spoiler and changing the wheels will affect mpg a lot?
Also if I remove spoiler, will there be drill holes on my trunk lid? If so, then I guess there's no way to take off the spoiler to achieve the cleaner look of the normal gasoline Civics huh?
First thing is, remove 1 wheel off your car, put it on a scale, post the weight, then I can tell u if it's gonna improve or hurt your mpg
Rear spoiler, you can swap to a 2012 hybrid spoiler, should able to cover the existing holes, but without seeing your stock one off the trunk, can't tell you for sure, remove the spoiler and take a photo, I can tell u then
Well the point of removing the spoiler for me is that I don't want a spoiler at all. So using the 2012 spoiler still doesn't achieve the no-spoiler look of the normal gasoline 2013 civics. Maybe they have built in spoilers, but they don't look like something was tacked on :/
I was wondering about aerodynamics too. The hybrid wheels have tiny holes...the wheel is almost completely flat, whereas the EX-L OEM wheels have tons of open ports/vents. Plus they are 1" bigger.
1 - 4 of 4 Posts
