1 - 13 of 13 Posts
Putting my UR downpipe on tomorrow. Anyone have any tips tricks etc. will be doing without lift. Lol
Sent from AutoGuide.com App
I did it with a jack and stands. It wasn't very fun, but it's possible.
I'd consider these mandatory tools/steps.
-Cowl goes off first (Before you jack the car) there's a DIY on that.
-Have an O2 socket handy (I got the taller thin-walled cylinder-type one from O'reily and it worked fine)
-Have good mechanic's set with extensions and universal joints. (An offset or double off-set ratchet could be helpful)
-Small flat head screw driver (For removing plastic fasteners in the Cowl.
Recommended
-Impact gun (I use an 18v Milwaukee 450-lbs gun and it works great, even sheared a stud off of a friend's Fit) this will definitely help with removing the spring-tensioned bolts connecting lower OEM DP.
-A extendable magnet tool for removing/replacing/recovering those hard to reach bolts
-Ratcheting open ended wrenches 14mm/12mm/10mm IIRC.
And PATIENCE! Taking your time on this can easily take a couple to a few hours.
Reactions: jtsi2012
Discussion Starter · #6 ·
Recommended
I don't have impact gun. Just arm strength
Reactions: Civi9
Bluestar's winch!!
Check out Arm0's thread on the RV6 downpipe. I'm going to guess the UR downpipe is a lot of the same, just to get the stock downpipe out. Once that part is over with, it really should be painfully obvious how to put the new downpipe on.
Cowl removal DIY
RV6 Downpipe DIY
Install wasnt that bad at all. I did mine in my garage with jack stands. Oy thing that took long was removing the cowl then those 2 stupid spring bolts that were a b***h to remove. Other then that its a pretty easy job. Also when u get to the air fuel ratio sensor disconnect it from the plug. I did the mistake of pulling it by the pins & had to waste $100 in buying a new sensor from honda
downpipe install
If I installed pipe would car still pass emmissions?
If you install a downpipe without a cat then defiantly no. If you install a downpipe with one highflow cat ceramic probably not but it will be closer than a metalic cat downpipe which will probably not pass an emission test either. Remember the stock downpipe has two large cats and the high flow catted downpipe has one that is made to flow first and foremost.
1 - 13 of 13 Posts
