1 - 2 of 2 Posts
So I'm sure there is a lot about the rev hang for the 9th gen civics here already, but I couldn't find anything to see if I'm the only one experiencing this with my KTuner.
So according to the site I'm suppose to put the Overrun Throttle Compensation to 0% to get rid of the rev hang. I did that, and when I'm driving normally on the roads its gone and shifting fine, but the problem is when I'm on the highway shifting at 3K plus... When I'm shifting on the highway it feels like there's a delay when I let off the clutch and shift (not smooth at all). When I noticed this I put the Overrun Throttle Compensation back to 100% and the issue on the highway was gone.
I just wanted to know if anyone else with a KTuner was having the same issue as me and if so how did you fix the issue.
Also, just wanted to add that I do the clutch delay valve delete to see if it would help at 0%, but nothing.
Discussion Starter · #2 ·
Issue resolved... went back to the factory base calibration from Tune 1 on my KTuner and the delay went away.
I'm going to try and mess around with the overrun fuel cut settings with Tune 1 and see if that helps as well.
1 - 2 of 2 Posts
