1 - 9 of 9 Posts
Hi there, i'm trying to do this on my Non-Navi Si 2015 with ADExternal 's guide but seems like the Reverse trigger (pin #14) is not working or the i-Mid for this latests model has been changed (?).
Tried with different cameras and nothing. I can see the camera if i enter in Diagnotic Mode.
The thing is when i put the Reverse, the imid doesn't do anything like ignoring the reverse.
I was thinking that my reverse or the wiring in the trunk was wrong, so i take it from the Fuse box and NOTHING.
Then, i was thinking that the PINs on the i-mid connector wn't doing contact SO i opened the i-mid (yes, im crazy :p) and soldering some wires directly to the pins in the board of the i-mid and doing the wiring from the reverse and camera video/ground directy AND NOTHING.
I 've tried almost everything in order to Debug but not luck.
Any ideas?
View attachment 426626 20160928_123950.jpg 20160927_161113.jpg 20160928_115543.jpg
not sure what you are attempting to do or accomplish. your car came with back up camera, or should have as standard equipment. what is it you are wanting as the end result?
Mi car doesnt have any camera. I have an aftermarket one and want to use it with the iMid.
I thought all Civics from 2013 up came with a back up camera? Was your car involved in an accident that could have broken the camera and who ever fixed it didn't bother replacing it?
I think he is in a different country where the backup camera is not standard.
Reverse camera is not standard here. I bought the car New 0km. So im 100% sure it doesnt come with camera from factory for this market.
This worked on my 2012 Civic eBay back up camera. Powered camera from reverse lights and fed three wires up front to imid. camera power ( reverse light ) ground and video signal A19 yellow (video feed) you can test video feed at back by putting car in reverse and put video feed in to monitor to test or small tv.
See pictures for wiring diagram of Imid of 2012 Civic North America. 9B7CDC71-45BC-42C7-A648-E3D85AB66E27.jpg 0D9DDC30-EBB4-410B-8FAA-A0BE47F8111E.jpg
The second thing you can try is supplying 12 volt dc to pin 14 from battery. This should turn on reverse imid. It could do damage if the pin out is different from before. Be fore warned. Have you supplied pin 18 with the camera ground?
1 - 9 of 9 Posts
