1 - 14 of 14 Posts
New ss catted ktuned downpipe. Wrap it or let er shine.
*NOT the cat just the 3inch piping.
Any experience or anything to recommend.
Good Call with not wrapping the cat.
As for the rest. it will make a small difference, nothing you will feel.
It's not a bad idea. Help keep bay temps slightly cooler. Although you can't really see it, I like the wrapped manifold look.
Fair warning - if you wrap your downpipe it will fatigue faster and fail sooner.
Even with t304 stainless steel? Plz explain why this would happen. By failing do you mean cracks and hole? Thanks.
Believe it's due to keeping the all of the heat inside the pipe, instead of letting it dissipate underneath the car.
I believe the main arguement would be the wrap can hold moisture. I don't think the heat is really an issue. I had my downpipe ceramic coated to help keep the underhood temps down.
Discussion Starter #9
Thanks dpetro, I just read about the wraps trapping moisture over 5 different websites. And it is a risk even with stainless steel.
I don't have a problem with the wrapping in a fiberglass I went to Home Depot and bought fiberglass cloth big sheet shredded would high temperature paint header paint goes up to 1700 degrees some of it I sprayed it with Rust-Oleum Grill paint it goes to 1200 and so far I haven't caught fire tested it out even hit it with a blowtorch big one and already tested my exhaust temperature in my cat too and they get to 1700 at 90 miles per hour I don't have a problem with the fiberglass
2015 Honda Civic Si Coupe
Ceramic coating is the way to go. Exhaust wraps can be dangerous. If oil gets on the wrap, it can catch things on fire.
Glad I paid RV6 to ceramic coat then.
I'd go bare, or ceramic coated personally... I see it as a maintenance issue being avoided. If you wrap it, it'll collect crap over time and you may need to replace the wrap/etc. And *if* it contributes to premature failure... Then you're better off avoiding it. Full disclosure, my first catless downpipe from Fullrace had the O2 bung fatigue and break. I got a replacement from them and they completely redesigned to use a cast portion at the top where the bung is. I guess the point is, even stainless can fatigue and break, no reason to increase the chances of that happening.
1 - 14 of 14 Posts
