981 - 1000 of 1007 Posts
Merged (10).
What size tein isolators fit the skunk2 springs ..wanna give them a shot before i ditch the springs thanks...and any pics on where to install them up front? Im guessing towards the center of the spring
Didn't use at the front.. No noise.. Sorry only used the tein rubbers at the back and it's night and day.
But you still should buy tein isolator for the front.. I'm sure it's gonna fix your prob.
I used 130mm for the back and fits perfectly... For the front just measure it on your car and get the closest tein sell. Prob around 90mm
Oh and the best with tein... Extremely durable and you don't need to remove anything they are made to be installed while everything is still mounted.
im about to get this springs.. would i be needing rear camber, front camber or both? (new here)
I don't care about negative camber so I opted out of the camber kit.
It has been shown that bad toe angle is what kills tires. So if you're worried about tires just get an alignment and ask to have toe adjusted close to stock.
But if you are worried about negative camber just get a rear camber kit you don't need it for the front
thanks bro!
20151212_160433[1].jpg 20151212_160407[2].jpg another perspective
ive read almost all the posts about these lowering springs I just want to make sure I got it right. camber kit is not needed but recommended and to prevent any noise the bump stop needs to be cut? overall everyone seems pretty happy with these hope I'm not the lucky guy to have problems with them.
