1 - 7 of 7 Posts
· Registered
Hello all!
I've been doing some research on wheel and tire fitment, and I learned a little more about how offset works. There's a set of wheels that I like by Japan Racing, but I'm unsure how good of quality this brand is. Has anyone had any experience with them?
I'm looking into getting these wheels as 18x8.5 +38, and hopefully get a pretty nice looking/flush fitment. I'd also be sticking with the 225/40/18 tire since I've read that 235 is kind pushing the limit on the available width we have.
I currently have stock suspension, but I may look into getting a set of swift spec-r springs later down the line. Though, with the stock suspension setup and no work to the fenders, would I run into any weird rubbing issues? I'm unsure what rubbing would look like.
Would be nice to get an opinion on the wheels too! They're kind of similar to the Advan TC-4s, but I'd get yelled at for spending $3K on some shoes. :(
Wheel Product Font Bicycle part Rim
· I Need A Vacation
Not saying they are bad but I've never heard of this brand I would stick with more established brands like Enkei or OZ which usually won't break the bank but still offer high quality.
With that wheel and tire setup on a stock suspension you won't rub even with Swift R springs with a mild drop you should be fine.
· Registered
Thanks for your insight Kev! I bet I can find some that look similar from OZ/Enkei. I'll keep researching!
· Registered
I was checking these wheels out from Work. Though, they offer these in a 18x8.5+45 and a 18x8.5+35, but i'm unsure if +35 will poke out a bit too much and the +45 will be too inwards and not clear the strut towers.
They're pretty cool!
I'll have to do some measuring, but willtheyfit says:
18x8.5+35: 22.7mm additional poke / 2.7mm closer to strut.
18x8.5+45: 12.7mm additonal poke and closer to strut.
1 - 7 of 7 Posts
